| Posted: Feb 21 2005 at 7:27am | IP Logged
Ok, Friday I finally got to take my truck in for my problems and this is how it went:
1) Power steering fluid leak.... FIXED they had to replace the hose and clamp that distributes the power steering fluid
2) Brakes....  FIXED but not really, they did the TSB that they resurfaced the roters and replaced the pads, however 2 days after this is done, the judder is very faint but coming back
3) The white spots on the Bed liner....  NO CLUE my dealer took pictures and are sending them to Nissan corporate.  The service manager said that they will probably tell them to dye it black.  I told them no way that is going to happen.
4) Gas Gauge....  NO CLUE they said that they see the problem that it isn't reading correctly and they have no idea what it is.  They thought it was the sending unit but said that it is reading correctly.  They are also going to contact Nissan about this problem
5) Tick rattle behind dash.   They told me this is normal, it is from a Heat Pump???  that sits on the firewall that puts coolant throughout the truck.  No I don't know whether to believe them or not..
So out of the 5 things, 2 were fixed, one is already failing, 1 is normal and 2 Nissan needs to get involved.
I also go a call back from Nissan Consumer Affairs about my complaint, however I wasn't at work to get the call cause I had to take a vacation day at work to have my truck worked on since they wouldn't offer me a loaner and I don't have a second vehicle.
I hate my truck more and more everyday....
By the way it now only has 2700 miles on it, I have owned it for 2 months and has been in the shop twice so far...
Mark
  __________________ 2004 Nissan Titan King Cab Smoke
