| Posted: May 26 2005 at 11:20pm | IP Logged
HavockWK wrote:
.... the consensus is to remove the half screen behind the TB when installing the TBS.
Whats the purpose of the screen?...and removing it? I just installed a PowerAid TBS last weekend...I didnt remove the screen, (oops??) nor did I have any fan clearance issues. It does however make the plastic cover fit less than perfectly, but it still goes back on. I purchased the TBS mainly with the hopes it would improve my milage. I will post an update on my mpg next week after my 300 mile roadtrip this weekend....
PS I know the TBS says "the whistle lets you know its workin" but mine sounds like an air leak...is that the "whistle", or did I install it incorrectly??
muddytruck Newbie
| Posted: Jun 01 2005 at 8:28pm | IP Logged
if you didnt put the rubber O ring in it might sound like a leak, but it def has a whistle. the issue w/ the spacer wasnt with fan clearance its just a matter of having enough space for the intake tube.
__________________ Silver 4x4 King Cab, 6" Stage II Pro-Comp lift, 305/65/17 Pro-Comp, Xtreme A/T, volant intake, banks monster exhuast
| Posted: Jun 02 2005 at 10:45pm | IP Logged
muddytruck wrote:
| if you didn't put the rubber O ring in it might sound like a leak, but it def has a whistle..... |
I used the rubber O-ring supplied with the TBS....2 tankfuls of gas, so far no measurable improvement in gas milage....I think I spent $100 for an intake whistle....lol
WheelinJeeper Groupie
| Posted: Jun 05 2005 at 5:39pm | IP Logged
I've put a cold air system on but that diden't require removing the Throtle Body is anybody know why this screen is in there?
muddytruck Newbie
| Posted: Jun 12 2005 at 9:02pm | IP Logged
hey puff, you might not notice fuel mileage increases, but you should notice a little extra power when passing vehicles on the hwy
wheelinjeeper, why would you want to remove your throttle body? that's part of the fuel delivery system.
socalsean Newbie
| Posted: Jun 13 2005 at 4:34pm | IP Logged
The screen is most likely there to prevent the trunk from injecting things that shouldn't be sucked into engines...IE dirt, leaves, skittles, etc.
You could probably remove it for more airflow, but the gains probably wouldn't outweigh the safety feature of the screen.
sean
| Posted: Jun 13 2005 at 5:36pm | IP Logged
...The screen is most likely there to prevent the trunk from injecting things that shouldn't be sucked into engines...IE dirt, leaves, skittles, etc. ....[/QUOTE]
I'd prolly agree with your assessment if the screen covered the entire intake, but it only covers the top 1/2 ..?????
socalsean Newbie
| Posted: Jun 30 2005 at 10:12am | IP Logged
thepuffman wrote:
...The screen is most likely there to prevent the trunk from injecting things that shouldn't be sucked into engines...IE dirt, leaves, skittles, etc. .... |
[/QUOTE]
hmmmmm....maybe the other half got sucked in already :) Haha...I really don't know why then.
sean
HavockWK Newbie
| Posted: Jul 19 2005 at 1:55pm | IP Logged
Nobody I know of has any real idea why the screen is there. As mentioned it only covers half of the TB and the holes in the screen are too big to stop anything smaller than a skittle. As for removing it, some people claim it helped when they did, but I have never done this mod, so I am just passing along the info.
If you don't have an aftermarket CAI (Volant or K&N) then I don't think there are any fitment issues with the stock intake and a TBS.
And yes I have heard the whistle before on a friend's truck and it is more of a hair raising screech than a whistle. This is the very reason why I am not going to do this to my truck, even if it did give me 1 mpg or a small power gain.
__________________ Havock
Deep Water Crew Cab SE
Big Tow -- Utility Bed -- Off-Road
Born 01/04
PRG 2.5" Front/1.5" Rear Lift
Havock's Titan Page
