| Posted: Aug 13 2004 at 6:55pm | IP Logged
I checked my rear differential fluid level and it was low. So, after surfing the net and talking with a few Nissan dealers, I came to the conclusion that Amsoil 80W-90 gear lube was the best lubricant on the market. Simply put, it is the best synthetic lubricant money can buy.
http://www.amsoil.com/
My dealer told me this is what Nissan uses for differential fluid in Titans. It's got the consistency of molasses. Since this truck generates so much torque, I can't see using anything else to keep the ring and pinion gears from grinding against one other.
This stuff isn't cheap, however. A quart of gear lube goes for $7.65, but well worth it when I consider how much I paid for this truck.
