| Posted: Jul 19 2005 at 10:22am | IP Logged
This noise almost made me go insane last Sept. I dissassembled the glove box and air box trying to find the noise because I swore the noise was inside. The ticking would only occur under a load, so simply revving the engine in park would not create the noise. Anyway, to simplify the story; I found the same tiny black wire, low on the passenger-side firewall running perpindicular to the aluminum a/c compressor line. I thought damn, I wonder if that tiny wire is smacking the compressor line when the engine rocks. I grabbed a trusty cable tie, tied the wire to the aluminum line, and voila. The cable tie is still there, the noise is not.
I fortunately do not seem to have a grounding issue. I have never heard the ticking again. Hopefully this helps someone keep their sanity.
