PatrickW Newbie
Posted: Nov 11 2004 at 2:48pm | IP Logged
This tube sounds great in the truck. The bottom in fills nicely. Sounds deep and hits about as hard as my old single voice coil 10's used to sound in my S-10. The only downfall is that the single seat in the crew cab won't raise from the floor up anymore, but it does fold top to bottom. The speaker wire is long enough to pull out and set in front of the seat if I need to put it up or simple disconnect it and put it back in later. I have a 300 watt Alpine sub amp pushing it and had to turn off the bass boost gain because it was drouning out everything else in the truck if you didn't have it cranked all the way up. Sounded great, but not for daily low listening levels. The power gain is about 3/4 of the way up. Not bad for $400 including install.
Johnboy Senior Member
Posted: Nov 11 2004 at 10:22pm | IP Logged
Hey that tube tucks away real nice down there. Sweet!
One question tho, how do you have your Alpine pre-amp wired into your system? Do you have the RF setup (mine does)
John
__________________ Johnboy
PatrickW Newbie
Posted: Nov 12 2004 at 8:58am | IP Logged
No, they used a low line converter off of the right rear speaker leed. Worked out just fine. I have the six disc in dash unit.
Cronus Moderator Group
Posted: Nov 12 2004 at 11:45pm | IP Logged
I'd love to find a subwoffer that'll tuck away like that but still provide all functionality of the seats. If you hear of anything like that, please let me know.
PS - That setup look great!
My Titan @ SLLAR.com
PatrickW Newbie
Posted: Nov 13 2004 at 10:27am | IP Logged
You probably won't fnd one that allows the seat to still work as that is where the top of the goes when lifted. Like I mentioned all you have to do is disconnect two wire and pull the sub out when needed, or just move the sub to the front of the seat in the cargo area for the short time it will be up. There are a couple of companies that make regular truck boxes for the Titan. Just go on yahoo and search : Nissan Titan Subwoofer Boxes. You get several different companies.
Posted: Nov 15 2004 at 12:20pm | IP Logged
Does Bazooka still make their 6 inch tubes? A pair of them might work but now the cost of the project doubled. Just a thought.
PatrickW Newbie
Posted: Nov 15 2004 at 2:03pm | IP Logged
They do male a 6", but it won't sound any better than if you put a pair of 6" midbasses in the rear door. I wouldn't go for less than an 8". Chaeck out their web site for more info on the products.
http://www.sasbazooka.com/
Posted: Nov 15 2004 at 6:43pm | IP Logged
I have an ooollldddd bazooka 10 that would take about 600 watts. I should put that in
