| Posted: Jul 21 2004 at 10:54am | IP Logged
Drew wrote:
| Does a lift void any warranties? |
Read this..It's some interesting reading..
www.sema.org/warranty
A dealer has to prove the aftermarket parts you installed caused the failure...For example they can't say "well your headlamp housing has condensation in it from you lifting your truck so it makes it sit higher in the atmosohere" or your window motor blew out cause of the lift kit..But they can say well your ball joints are no good because of the lift,so you gotta pay out of pocket.....
It has to directly have something to do with the problem to void your warranty,they can't just say your warranty is voided cause you modified your truck...
