Subject Topic: oil pressure gauge problem?? Post ReplyPost New Topic
newhope
Posted: Mar 25 2005 at 12:51pm | IP Logged Quote newhope
I have a 04 LE with the big tow package every time i get on the gas the oil pressure gauge neddle goes all the way to high is this a problem or does everybodys do this ?
Back to Top View newhope's Profile Search for other posts by newhope
The Engineer
Posted: Mar 25 2005 at 4:23pm | IP Logged Quote The Engineer
its supposed to do this, Nissan was one of the few companies that actually sends updated data to that gauge, whereas all other companies leave it fixed unless there's a problem.
2004 Titan SE Kingcab
-Smoke Gray
-Big Tow Package
Back to Top View The Engineer's Profile Search for other posts by The Engineer
newhope
Posted: Mar 26 2005 at 10:53am | IP Logged Quote newhope
Thanks for the info MR ENGINEER
snguyen
U.S. - Oregon
Posted: Apr 13 2005 at 3:06am | IP Logged Quote snguyen
yeah mine does that too!  It actualy didnt do it until about 7,800 miles.... so "Mr. Engineer" can you explain that?
Back to Top View snguyen's Profile Search for other posts by snguyen
stitch
Posted: Apr 13 2005 at 4:45pm | IP Logged Quote stitch
Well the gauge does respond well. What is too high is relitive.
Cold oil will give higher readings
Higher RPM - same
Thicker oil - same
At operating temp my gauge reads a bit over 1/2 at idle and maybe 3/4 at revs.
I used Havoline 5W30 during break in and Castrol syntec 0W-30 now. Strangely, the 0W30 gives slightly HIGHER pressure than the 5W30 did. Some 30W oils are thicker than others at operating temps.
High pressure isn't necessarly a problem but did you change the oil weight or filter -? or was it always reading like that.
cruzr1_jr
Posted: Apr 17 2005 at 12:03am | IP Logged Quote cruzr1_jr
I'm having the same problem with my 04' titan. Didnt start until after my first oil change. My oil preasure gauge always pegs out at high when I start it up in the morning even on warm days. And it takes a good 10-15 mins for the preasure to level out. And even then when i drive it, when i hit the gass it preasure goes up and it feels like its dragging and not shifting properly. I took it in to the dealer to get checked out and they told me it was normal. Is anyone else having this problem. Just wondering if this is normal and th 04' just drive like crap.
Back to Top View cruzr1_jr's Profile Search for other posts by cruzr1_jr
shizod
Posted: Apr 22 2005 at 4:32am | IP Logged Quote shizod
Well cruzr1_jr I dont think that your engine oil has anything to do with shifting, if your having a problem with shifting then it is probably occuring in the x-msn. But what your saying about the oil guage sounds pretty normal I have always owned fullsize trucks and thats what I have always experianced with the oil guage. However if the guage is pegging out at max then I would get it checked. But upon start up is should be high and then level out as the engine warms and of course if you are rev'ing high or racing then it should be high as well, but not maxed out.
05 KC SE 2WD
Rockford, Big Tow
smoke grey
volant intake
HID conversion 5000K
Back to Top View shizod's Profile Search for other posts by shizod
