ocracer Newbie
| Posted: Oct 21 2004 at 4:24pm | IP Logged
well here's my question, I'm waiting for an '05 titan crew cab SE. it's going to be my first full-size truck and I have A TON of mods in mind. Starting with a lift kit, I already know which kit I'm going to run but, I'm also going to be doing some big performance mods. I'm going to be running 38 inch tires and I really want to be able to do some nice burnouts, only problem with that, watching one wheel spin is really lame, does anyone know if the 05's are going to come out with a locking rear diff? I know it comes standard on the offroad package, but since I'm changing all that anyways, I'm just getting the basic suspension package. and I'm only getting the 2-wheel drive not 4x4. well, any help would be awesome, thanks
fla titan Groupie
Online Status: Offline Posts: 48
| Posted: Dec 04 2004 at 3:17pm | IP Logged
good luck turning those 38" tires it has the torque to do it but your
going to wind up doing more harm than good. why would you put
tires that big if its not going to be 4x4? also you are looking at over
$2000 for a lift kit to fit those tires under the titan. but its going
to be your truck and good luck
__________________ 2004 se kc 4x4 smoke grey
ned946 Newbie
Online Status: Offline Posts: 31
| Posted: Dec 04 2004 at 11:12pm | IP Logged
I'm not looking to do burn outs, but I would like to get more info on a locker. I have a 2wd and I feel a locker would benefit me....is there a way to get the factor locker?
Also, where can I get details on the guts of my Dana44?
What kind / brand locker is it?
Air driven/ electric or a mix?
Who makes the locker?
__________________ Nissan Titan Forum
fla titan Groupie
| Posted: Dec 05 2004 at 12:15pm | IP Logged
i have the 4x4 with the big tow package and i dont have the locking
rear differential . i think the only way you will beable to get the
locking diff if you got the off road package im not sure on the
manufacturer mut your owners manual should point you in the right
direction if not look up the dana site online
Tidefan Newbie
| Posted: Dec 07 2004 at 11:33am | IP Logged
The '05 4x4 package has a locking rear diff.
EDIT
Umm....forget what I just said....didn't read your post all the way through.
__________________ '05 LE CC....LOADED!!!!
stitch Groupie
Online Status: Offline Posts: 53
| Posted: Dec 07 2004 at 1:00pm | IP Logged
Also, where can I get details on the guts of my Dana44? ( It's a "modified" 44 , I know even the rear cover is different than a plain 44)
What kind / brand locker is it? (Eaton)
Air driven/ electric or a mix? (Electric)
Who makes the locker? (Eaton)
http://automotive.eaton.com/product/traction_stability/elock er.html
ned946 Newbie
| Posted: Dec 07 2004 at 7:44pm | IP Logged
Thank you thank you!
Would you happen to know if its available aftermarket for the titan?
stitch Groupie
| Posted: Dec 09 2004 at 10:47am | IP Logged
I don't know off hand. As with shocks,brakes and other add-ons etc. It's taken about 1 year for the aftermarket to catch up with the Titan. The simple things came/come faster and the more complex parts come slower.
I would think that a locker and other drivetrain components take 1-2 years to introduce after a completely new model truck hits.
NorthTitan Newbie
| Posted: Dec 14 2004 at 1:25pm | IP Logged
Bought a late 2004 model with the diff lock. After reading the manual, I found out that the lock only works when in 4LO. That means it is of limited use. I think that I would rather have the VDC for winter driving. I am investigating if it is possible to add the VDC or change it with the diff lock. I've heard that you can't have both.
__________________ NorthTitan
2004 4x4 Kingcab SE Canyon Red (Canada)
Offroad Tow Versatility pkg
Nissan brush guard, side steps, grills inserts; Eagle Eye driving lights
fla titan Groupie
| Posted: Dec 14 2004 at 6:07pm | IP Logged
what is the vdc exactly?
