Posted: Nov 16 2004 at 4:15pm | IP Logged
I have had zero problems with the Nissan installed XM Radio with the "stick" antenna attached to the drivers side rear window.
I'm confused what you mean by forcing the stick to stay in the same spot? Mine will move in the 180 degrees pointing up, pointing down or anywhere in between and it stays exactly where you position it. It feels like "stepped notches" of position.
Please let me know....I love XM Radio and would be truly upset (as you are) if I had those problems. I'll see what I can find out!
