| Posted: Mar 27 2005 at 9:42pm | IP Logged
I recently bought a used titan and its awsome, but on my way home after picking it up i noticed the volume on the stereo goes down when i slow down and gets louder when i speed up, this is quite annoying and i wish it would stay at the same volume level. Also when it quiets down or gets louder its not indicated on the display like it would be if you adjusted it yourself showing the number level of the volume. I once found a post with the titan's manual but now that i need it i can't find it again. So does anyone know if this is an option that can be turned off or is it a glitch i would greatly appreciate your replys.
