WheelinJeeper Groupie
| Posted: Feb 06 2005 at 10:59am | IP Logged
Has anybody purchased the set of four that are allways on E-Bay for like 350. Are they any good? Will they not worpe like the stock ones?
| Posted: Feb 08 2005 at 7:03pm | IP Logged
If they are just as thin, then they most likely will warp just as bad but they might not do it as quickly as the factory rotors as they would get cooler faster.
| Posted: Feb 08 2005 at 9:31pm | IP Logged
Ya I guess I'll just call the dealership and let them fix it.
| Posted: Feb 11 2005 at 9:50pm | IP Logged
Stopped by the dealership today to make a appointment the fixed it right then and there. They but a new style brake pad in they replaced the caliper bolts with a upgraded set, and they put brand new rotors on. They work like the day i drove it off the lot.
| Posted: Feb 17 2005 at 2:25pm | IP Logged
Mine did to for about 2 months and then our frined jutter appeared again
Prlauren Newbie
Online Status: Offline Posts: 38
| Posted: Feb 18 2005 at 6:23pm | IP Logged
Bought the slotted/cross drilled rotors and carbotech brake pads will let you know how it works! Did not recieve them yet!
| Posted: Feb 19 2005 at 10:23am | IP Logged
I got the 22" rims I'll see if the biger rim lets more air circulate aroung the rotor and helps it not to get so hot.
