Subject Topic: More aggressive tires Post ReplyPost New Topic
wormetoungue
Canada
Posted: Mar 25 2005 at 3:41pm | IP Logged Quote wormetoungue
I was wondering if anyone knew of a mud or all terrain tire that would fit on my LE's 18 inch rims. Of course I would like to do this as inexpensively as possible, which means no cutting or lifting. I fear I may have to drop to 16,s but will they fit over the brakes?
Back to Top View wormetoungue's Profile Search for other posts by wormetoungue
yogibm1
Posted: Mar 28 2005 at 11:00pm | IP Logged Quote yogibm1
keep your regular tires and don't ruin a good truck with lttle rims! Get deeper Pockets and get the Nitto Terra Grapplers. in the 18"
I like to Win
Why does Bugs Bunny walk around naked and when he goes swimming he puts on trunks!
Back to Top View yogibm1's Profile Search for other posts by yogibm1
KTMNealio
Posted: Mar 29 2005 at 11:14am | IP Logged Quote KTMNealio
Toyo and BF Goodrich make tires that are close the the stock size and are a TON better than those crappy tires that come on there.
 - Nealio
Back to Top View KTMNealio's Profile Search for other posts by KTMNealio
bigbear05
Posted: Mar 29 2005 at 2:06pm | IP Logged Quote bigbear05
Good luck doing it inexpensivley. I wanted a better gripping and tougher tire, but I couldn't find any that I could afford. Had to end up going with the Continental Contitrac 265/70/18 for $450.00. Cheapest place I could find.
wormetoungue
Canada
Posted: Apr 03 2005 at 9:22pm | IP Logged Quote wormetoungue
Thanks fellas.
IQ9*
Posted: Apr 06 2005 at 11:41pm | IP Logged Quote IQ9*
Those Contis rate almost as bad as the Goodyears. But anything is a step up. BFG makes the All Terrain TA KOsin 275/65/18 or 275/60/18 nut it is a nearly perfect match in tire height. That is if you care about the speedo correction issue. I usually don't. The TA KOs do have a stiff sidewall but the do grip far,far,far better than the Crapyears. Good luck, I'm waiting for the tax returns before buying anything as we think we might need our first car seat
clayd-8
Posted: Apr 10 2005 at 10:24am | IP Logged Quote clayd-8
i have been having these brake problems .the rotors are to small for the weight of the truck so they waro from all of the heat.well nissan has what they call a bulletin(callback)if yo have 2 problems with the rotors on the 3rd trip they are installing the rotors with the grooves and drilled holes which disapates the heat.i dont think they are going to send out anything on it so i am just giving a leg up.
Back to Top View clayd-8's Profile Search for other posts by clayd-8
IQ9*
Posted: Apr 13 2005 at 1:06am | IP Logged Quote IQ9*
I am on my third set of rotors and Nissan did not provide a slotted or drilled option. They provided a thicker rotor but in turn you give up the height of the cooling vains in the rotor. If they do get you one way its another
