bigbear05 Moderator Group
Posted: Aug 12 2005 at 11:28am | IP Logged
Well I bit the bullet a little early and had it installed. I had the Flowmaster 40 series delta flow installed on my rig yesterday and man it sounds mean! Dropped it off at lunch and had a friend take me over after work to pick it up. The muffler shop guy said that mine was the first one he had put pipes on and none of his pre-bent pieces would fit so he had to bend all the pipe himself. I am very pleased with the outcome. All-though I am going to take it back this afternoon and have some squeaks looked at. I opted for the exits to be place behind the rear wheels tucked under the bed with only about 2 -3 inches showing. They are angled to the ground a little for more resonance. It's a little over-bearing at first, but once you hit crusing speeds around 60 to 70 mph it sound just like the stock system. The ole' "Tank" is turning some heads once again!! I'll get some pics this weekend and as soon as I can get my hands on a digital camera with video recording I'll post some sound pics.
Posted: Aug 12 2005 at 2:54pm | IP Logged
Congrats on the exhaust!
My Titan was a first also to be worked on when I took it to the muffler man. Same thing too, had to custom bend pipes.
Posted: Aug 16 2005 at 2:07pm | IP Logged
Looks like I will be hearing the same tune as the shop I am getting a quote from said they haven't done a Titan yet but they want to get under one and play.
Posted: Aug 16 2005 at 2:17pm | IP Logged
All the shops I got quotes from were amazed at all of the room underneath. I said if you think that's alot of room check out the cab. Apparently the Nissan Titan also owns the title of "Best in-class undercarrige room for placement of exhaust."
Posted: Aug 24 2005 at 10:58am | IP Logged
I am hoping to actually be able to do the exhaust this weekend but there always seems to be some stupid crap I have to deal with. Last weekend was spent removing the unsealed battery and putting in a sealed one. I can't believe that Nissan thinks a leaky unsealed battery makes sense in a 4x4 I had such fun cleaning the acid off the fender well, gravel guard,a/c hoses,bumper support and trying to get under the battery tray that can't be removed Thank You Nissan for such forward thinking.
blackjack7 Groupie
Online Status: Offline Posts: 90
Posted: Aug 25 2005 at 6:53pm | IP Logged
was the 40 series flowmaster a dual inlet and dual outlet? sound clip would be great.
__________________ blackjack7
Posted: Aug 26 2005 at 7:23am | IP Logged
blackjack7 wrote:
was the 40 series flowmaster a dual inlet and dual outlet? sound clip would be great. |
Single in, dual out.
