fla titan Groupie
Online Status: Offline Posts: 48
| Posted: Nov 22 2004 at 5:48pm | IP Logged
Has anyone found a local store to get k&n air filters or cool air
systems with out ordering it on line? Also if anyone is looking
to put true duals on there truck i found a ast that allows performance
parts on your vehicle with out voiding your warrenty called the
magnuson-moss act. sorry so long
__________________ 2004 se kc 4x4 smoke grey
jmacougar Groupie
| Posted: Nov 22 2004 at 11:41pm | IP Logged
I wouldn't waste my time or money. I ordered the K&N intake kit and ended up sending it back. It was way too loud and my throttle response is a lot better with my stock air box. I guess they couldn't out-do Nissan this time.
Jason
fla titan Groupie
| Posted: Nov 23 2004 at 4:44pm | IP Logged
what about just the air filter? was the noise louder in the cab or outside?
GeneW Newbie
| Posted: Nov 23 2004 at 5:40pm | IP Logged
I wouldn't use anything other than the stock air intake, but if you want, you can use a K&N element for it. Just don't oil it up excessively or some may get to the intake air sensor or the mass airflow sensor which can create havoc with driveability. I've been repairing cars for 35 years and I've seen these chopped up intake systems that turn out to be the main reason they are at my shop in many cases.
__________________ Gene W
fla titan Groupie
| Posted: Nov 23 2004 at 7:44pm | IP Logged
cool now i have a question is the air intake enough to handle true duals?
jmacougar Groupie
| Posted: Nov 24 2004 at 12:10am | IP Logged
It was extremely loud in the cab. I can't imagine how loud it was outside while I was driving down the road. I do know the first time I punched it there were some kids playing basketball a good distance away and they all stopped and turned around to see what the heck was going by. It was so loud it sounded like I didn't have an intake on there at all. I've had intake kits on two other vehicles, they gave them a cool sounding growl, but nothing as obnoxious as this one sounded.
But my biggest disappointmet was the throttle response. I might have been able to live with the noise if I hadn't lost my power range and torque. Instead of having power from any throttle position it went to on/off. There was absolutely nothing in between except for noise. I still wish it would have performed better because it sure did look cool.
treebasher Newbie
| Posted: Nov 30 2004 at 8:04pm | IP Logged
I put on over 100,000 miles on my last truck 70,000 miles with the
intake. I never had any problems with the K&N intake.
I have over 11,000 miles on the Titan now with the K&N filter
charger. Yes, the charger is louder but mostly only at WOT (wide
open throttle). At idle and below 3,000 rpms there is no
difference inside the cab from stock. I actually tested it before
and after, less than 10 dB. The only way people know I have and
intake system is by stamping on the gas. And since I don't drive
around hammering on the gas all day, it's not a big deal.
No loss in power or response here. No dyno in the garage to test
that (since that's the only way you'd ever notice the little difference
an intake would make). I'd say that's the worst part about it,
you barely notice it's there.
Non-restrictive air flow is always a good thing, on the way in and
out. If you can't get the air in, putting on duals is just making
noise.
Just my .02
__________________ Silver
2004 Titan SE Crew
Off Road
Tow Package
Soft Tonneau
Westin Bull Bar
fla titan Groupie
| Posted: Dec 01 2004 at 9:30am | IP Logged
did you install the charger yourself? if so where did you buy it?
im a little sketchy about ordering things on line but if you can tell
me where you got your set up i would appreciate it
treebasher Newbie
| Posted: Dec 01 2004 at 7:58pm | IP Logged
I purchased it online. Installed it myself as well.
Seriously, it was really easy. The directions are very complete.
I ordered it from www.courtesyparts.com Just click on the Titan 2004-2005 link.
They are a Nissan dealer in Texas. I live in Minnesota and they had it here in a couple of days.
My only word of advice on installation. Pay attention to the
instructions when putting the air flow sensor in the new housing.
It must face the right direction.
2004 Titan SE Crew
Off Road
Tow Package
Soft Tonneau
Westin Bull Bar
jmacougar Groupie
| Posted: Dec 01 2004 at 10:15pm | IP Logged
I will say it was easy to install.
K&N did tell me there are rare cases where the truck doesn't like it, but didn't buy it. I've had two other cars with K&N filter chargers on them and I was extremly impressed the results, but I guess I had high expectations this time.
