soldierangel Newbie
| Posted: Dec 13 2004 at 2:13pm | IP Logged
Well I've done a search to see if anyone else has had a similar problem, but found nothing. When I fill up the tank, if I fill too fast, the gas will overflow from the tank. Not because it is full, but it is getting stopped up somehow from being filled too fast. This happens nearly everytime. How would I correct this problem, or is this just something I need to deal with?
Thanks in advance.
koncept Newbie
| Posted: Dec 13 2004 at 2:46pm | IP Logged
well mine stops its just that i try to get it to the nearest dollar and sometimes it ends up in my finding gass running out
Mitch Senior Member
| Posted: Dec 13 2004 at 4:52pm | IP Logged
I've never had this problem. Maybe the pump is pumping to fast, put the nozzel handle latch down a notch and see what happens.
__________________ Mitch
BMWTitanMan Newbie
| Posted: Dec 13 2004 at 5:32pm | IP Logged
my dealer thinks im insane i showed them on my truck where the gas ran
down and cleand the dust off my truck and they still did not believe
me--ithey can never duplicate it i can atleast once a week.--3rd repair
attempt on the gas over flowing--ok there in no WRON(to far in to far
out) way to pump gas i should not have to adjust a gas pump in the
filler neck for a 30.000.00 truck--lemon law truck--getting an '05 love
the truck --hate the problems
camino70 Groupie
Online Status: Offline Posts: 55
| Posted: Dec 13 2004 at 6:07pm | IP Logged
I had a loaner before they delivered my truck and every single time this truck overflowed, the dealer tried to blame it on the gas pump. But it happened at five different stations, all of which I have used with previous vehicles.
So far I haven't had it happen on my truck, I let it sit for a few moments and then fill on the slowest possible selection.
Ron
__________________ '04 Canteen LE 4X4 no packages, no mods, yet...
soldierangel Newbie
| Posted: Dec 13 2004 at 7:30pm | IP Logged
Well this problem was not from topping off the tank, it happened everytime I filled up from the start. Well I contacted Nissan service department and they said it is a problem with some of the trucks having a kink in the hose and it was an easy fix. I will be stopping by there tomarrow to get it worked out, and I will update you all how it works.
jmacougar Groupie
| Posted: Dec 13 2004 at 10:16pm | IP Logged
I've had the same problem. TWICE! I didn't think anything of it when it happened because I figured I had the pump in wrong.
camino70 Groupie
| Posted: Dec 14 2004 at 7:44am | IP Logged
When I had the loaner, I never filled it. I only put a few dollars in at a time, I thought my truck would be ready for me sooner then it was...
And it happened almost as soon as I started to put gas in it.
Ron
TonyG Newbie
| Posted: Dec 14 2004 at 9:19am | IP Logged
I have the same issue. my service rep told me someone in his family had the same issue.
__________________ Tony
soldierangel Newbie
| Posted: Dec 14 2004 at 4:11pm | IP Logged
Well there was no kink to be found and no ubstruction, he thinks that it has something to do with a problem the 350Zs had in that a regulator will not let enough air out as the tank is filled, causing the gas to get backed up when filled too fast. He is supose to call me later today to let me know what they are planning on doing. If it's what he thinks, the part will be overnighted in, and I can have the truck fixed tomarrow.
I also must say that Nissan has got to have the best customer service I have ever seen. Or maybe it's just here in Oklahoma.
