| Posted: Dec 19 2004 at 9:20am | IP Logged
So I took it in a few days ago to have the once over done.
I complained of brakes shuddering when I brake hard, the drivers window not coming up, a vibration at idle, a very noisy rattle in the front end, and the gas spewing from the tank problem.
OK, 1st off they changed out my rotors, pads and a few other brake parts. For the window thing, they said they all do that and it is a safety feature of some kind....I guess I can live with that.
For the rattle I had, they found that the entire front bumper assembly was loose as well as the hood latches. So they had to completely remove and reinstall the front bumper assembly....NO MORE RATTLE :D
OK, get this...for the vibration I felt at idle, they wrote "checked balance on all 4 tires, found out of balance tires and rebalanced all 4 tires. HHAHAHA They must have been pretty far out of balance to cause vibration at idle.
As for the tank not accepting gas problem, they said they could not duplicate it. I knew I shouldn't have dropped it off with a 1/4 of a tank...only does it on empty. Anyway a different, more knowledgeable service rep told me that the problem is with the tank and that they will be replacing the tanks, but that they are on super duper back order and it could be months.
