| Posted: Jan 23 2005 at 9:08pm | IP Logged
I had same problem...to see what other drivers are seeing just step out in front of your truck and crouch down to about the level an oncoming driver would be and see for yourself.....took it back to dealer and they said they were correct...so I adjusted them dowm myself....under hood, behind and at top of headlight is a torx 15 screw adjuster...I just parked about 50' from a building on level ground and adjusted them to about 4' off ground at that point....drivers side a little lower...this is just about right now...if you want to get technical go to one of these sites....not a link, you will have to copy and paste the address...hope this helps
http://faq.auto.light.tripod.com/hl-aiming.htm
http://home.att.net/~borrani/articles/tech/aimhigh2.htm
__________________ 2004 White SE King Cab,K&N Air Filter,Line X Bed Liner,XM Radio,LED Lights between tailgate and bumper
