royjratc Newbie
Posted: Jan 24 2005 at 3:46pm | IP Logged
Went out to start that trustworthy truck this a.m. - Key would not turn! Not quite sure why - Thought maybe steering wheel was locked - Seen that on other cars/trucks. But no amount of playing with the steering wheel while trying jiggle the key helps.
Of course, I can't even get the truck into nuetral now, as the shift lever won't move unless the key is turned.
Has this happened to anyone else? Any ideas before I have this towed?
__________________ Roy-NY
Posted: Jan 24 2005 at 4:25pm | IP Logged
I know the key has a chip in it, if something was wrong with it I assume it would still turn but not crank...not sure tho...I'd call the dealership first.
royjratc Newbie
Posted: Jan 24 2005 at 4:38pm | IP Logged
Thanks - I thought about the chip too. And my wife did put a snow encrusted key in yesterday!
jimb Groupie
Posted: Jan 24 2005 at 5:04pm | IP Logged
A 'snow encrusted' key, and you're in New York? What is it -- about -3 up there in the morning? This may sound completely obvious, but do you think sub-freezing temps and water-turned-ice in the ignition as a result of a snow encrusted key might be a factor?
jimb Groupie
Posted: Jan 24 2005 at 5:10pm | IP Logged
thepuffman wrote:
I know the key has a chip in it, if something was wrong with it I assume it would still turn but not crank...not sure tho...I'd call the dealership first. |
It'll crank just fine/beatifully with the wrong chip - right until you drain the battery. It won't start, however.
ZeroInteruppt Newbie
Posted: Mar 24 2005 at 5:49pm | IP Logged
Not sure if this is the same problem that you've been having but I have had two other nissan trucks and they ALL have the same problem. Every once in a while for no reason at all the key's just don't work. Usually i just have to play with it for a while. I have a 1991 Nissan SE 4x4, a 96 Nissan 4x2 (which I have since given away), and now of course my 05 Nissan 4x4.
royjratc Newbie
Posted: Mar 25 2005 at 7:28am | IP Logged
Actually - Jimb was right - Snow melted into the ignition & froze - Took 2 days before the temperature got warm enough & then it started right up
watsor1 Senior Member
Posted: Mar 29 2005 at 5:57pm | IP Logged
Actually you can get it into neutral without the key working. At the forward end of the console (I ass u me you have a floor shift) there is a little circular cover. Pry this puppy off and there is a release mechanism that will let you get the shifter out of park. The procedure is in the owner's manual, but I can't remember where.
Rick
Kevante Senior Member
Posted: Mar 29 2005 at 7:22pm | IP Logged
rick, That is a good idea. good thinking.
