shizod Groupie
Posted: Apr 27 2005 at 7:03pm | IP Logged
Hey there, I have removed the badging off my truck except for the nissan badging. However I want to remove the door trim moldings, what I was wondering, is the moldings held on by two sided tape like the badging on the door and tailgate, or are they held on with plastic studs and two sided tape. Thanks.
__________________ 05 KC SE 2WD
Rockford, Big Tow
smoke grey
volant intake
HID conversion 5000K
kytitan Newbie
Online Status: Offline Posts: 26
Posted: Apr 28 2005 at 2:51pm | IP Logged
The front door molding is held on with 2 sided tape and 2 plastic studs.
shizod Groupie
Posted: Apr 28 2005 at 8:46pm | IP Logged
that sucks....so if I want to remove them then I am also going to have to bondo and then paint?
Rockford, Big Tow
smoke grey
volant intake
thaimonkee Groupie
Online Status: Offline Posts: 88
Posted: May 02 2005 at 5:45pm | IP Logged
most liekly. most the time(if nto all) when shaving off the moulding you will need to fill the holes and repaint everything. but the outcome will be hella nice
Posted: May 19 2005 at 12:23pm | IP Logged
I wanted to do the same thing when we first got the truck and was told of the holes. Sorry, I should have posted it here so you would have known.
shizod Groupie
Posted: May 24 2005 at 2:26pm | IP Logged
No problem I kind of abandoned the idea, maybe one day I will do it but not now.
Rockford, Big Tow
smoke grey
volant intake
WheelinJeeper Groupie
Posted: Jun 01 2005 at 6:22pm | IP Logged
I'm trying to find door molding to go on my 04 crewcab i got the base model and it diden't have molding door ding suck
christopher Newbie
Posted: Sep 02 2005 at 11:27pm | IP Logged
i can understand de-badging, but taking off the factory door molding? they provide protection and they look great. go look at the base model...it is not nearly as nice looking. i am interested in de-badging my 05. how do i do it? i am guessing a heat the letter with a hair drier and gently pull. then just clean up the adhesive. is it this easy?
__________________ shut up and drive the thing
Posted: Sep 04 2005 at 5:23pm | IP Logged
There are many posts in the TITAN MODIFICATIONS about debadging. Fishing line, a ice scraper, gently pulling the moldings off are all ways in which people have tried. It's basically any of those that you can do easiest and with the least about of scuffing the paint. Warmer weather will help though.
socalsean Newbie
Posted: Sep 08 2005 at 11:29am | IP Logged
You can also use dental floss unstead of fishing line.
sean
