swami Newbie
Posted: Dec 10 2004 at 1:47pm | IP Logged
I have recently purchased my Titan and love it. I am new to this forum and not sure if I am posting this in the correct place.
Does anyone have a problem with the tail gate not seeming to latch or close "tight". Every time I shut mine, I have to open it and slam it shut to make sure it is closed all the way. Any one else have this trouble?
Posted: Dec 10 2004 at 3:05pm | IP Logged
It latches on both sides. I have to push on each upper corner, but that is because I built a bed cover that fits a little too tight.
NorthTitan Newbie
Posted: Dec 14 2004 at 4:28pm | IP Logged
Mine closes very easily. Almost too easily. I could close it with one finger. I think I would prefer a bit more snugness.
__________________ NorthTitan
2004 4x4 Kingcab SE Canyon Red (Canada)
Offroad Tow Versatility pkg
Nissan brush guard, side steps, grills inserts; Eagle Eye driving lights
TennTitan Newbie
Posted: Jan 20 2005 at 9:19pm | IP Logged
Mine closes fine but it is one heavy sucker! Wish that they had some kind of assist with such a heavy load.
jimb Groupie
Posted: Jan 21 2005 at 5:56am | IP Logged
There might be an alignment problem. It happens and is an easy fix.
Cperki1 Newbie
Posted: Jan 21 2005 at 9:36am | IP Logged
Tenn, They corrected that issue on the 2005 models. They have a system that will not allow the tailgate to slam down.
Edit: Called TeNN TeEn. Sorry.
__________________ 2005 2WD XE
"It's for work!"
TennTitan Newbie
Posted: Jan 21 2005 at 9:52am | IP Logged
I wonder if they can put on an 04 or is it a 05 thang?
MyOutdoors Newbie
Posted: Jan 21 2005 at 2:54pm | IP Logged
I just bought mine yesterday and found that same problem today.
It is so cold outside (-5F) that the rubber cushions between the
tailgate and bed couldn't expand to take up the "gap". I left it
in the sun and it was just enough to heat up the rubber cushion to were
they expanded enough to give a tight fit.
__________________ 05' KingCab LE 4x4
rapineda61 Groupie
Online Status: Offline Posts: 93
Posted: Jan 25 2005 at 2:10am | IP Logged
i had the same problem but was repaired, aligment only ,i think tail gate toooo heavy.04 le crew cab z grill.tinted,dvd.flow master, k&n filter,22 wheels,hard bed cover
04TITAN4SALE Newbie
Posted: Feb 04 2005 at 12:31pm | IP Logged
don't slam it to hard because it will break and be stuck closed like mine was for a month until the service department could fix it for me!!
__________________ Ed
